Hello,
I have a newly installed aaPanel Pro 6.8.33 running on Alma 8.9. The first plugin that I tried to load is Nginx WAF. It appeared to install but wouldn't work. I uninstalled and re-installed. When I click WAF, I get this on a white screen: Traceback (most recent call last): File "/www/server/panel/BTPanel/init.py", line 1583, in panel_other plu = eval('plugin_main.' + name + '_main()') File "", line 1, in AttributeError: module 'btwaf_main' has no attribute 'btwaf_main'
When I installed aaPanel, I ssh'd in as a sudo admin. Early in the install, I was prompted to be root. The install.sh file was already in my /home/user directory. Do I need to uninstall aaPanel and re-install it as root?
Thank you,
-- Gadmin
