/www/wwwroot# sudo systemctl status apache2.service
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2024-01-20 06:16:41 CET; 37s ago
Docs: https://httpd.apache.org/docs/2.4/
Process: 67752 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
Jan 20 06:16:40 vmi1610471.contaboserver.net systemd[1]: Starting The Apache HTTP Server...
Jan 20 06:16:41 vmi1610471.contaboserver.net apachectl[67765]: AH00112: Warning: DocumentRoot [/etc/apache2/var/www/htm>
Jan 20 06:16:41 vmi1610471.contaboserver.net apachectl[67765]: (98)Address already in use: AH00072: make_sock: could no>
Jan 20 06:16:41 vmi1610471.contaboserver.net apachectl[67765]: no listening sockets available, shutting down
Jan 20 06:16:41 vmi1610471.contaboserver.net apachectl[67765]: AH00015: Unable to open logs
Jan 20 06:16:41 vmi1610471.contaboserver.net apachectl[67752]: Action 'start' failed.
Jan 20 06:16:41 vmi1610471.contaboserver.net apachectl[67752]: The Apache error log may have more information.
Jan 20 06:16:41 vmi1610471.contaboserver.net systemd[1]: apache2.service: Control process exited, code=exited, status=1>
Jan 20 06:16:41 vmi1610471.contaboserver.net systemd[1]: apache2.service: Failed with result 'exit-code'.
Jan 20 06:16:41 vmi1610471.contaboserver.net systemd[1]: Failed to start The Apache HTTP Server.
[1]+ Stopped sudo systemctl status apache2.service
/www/wwwroot# sudo tail -n 50 /var/log/apache2/error.log
[Sat Jan 20 05:28:08.023251 2024] [authz_core:error] [pid 65329:tid 140715325642496] [client 162.158.189.135:63346] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:28:17.413797 2024] [authz_core:error] [pid 65328:tid 140715325642496] [client 172.71.154.70:42964] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:28:30.944142 2024] [authz_core:error] [pid 65329:tid 140715191424768] [client 162.158.175.45:58654] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:28:31.307741 2024] [authz_core:error] [pid 65329:tid 140715057207040] [client 172.71.174.198:13232] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:29:59.758954 2024] [authz_core:error] [pid 65328:tid 140715308857088] [client 172.69.34.68:34564] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:31:29.268971 2024] [authz_core:error] [pid 65329:tid 140715300464384] [client 172.70.114.145:29142] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:31:31.730056 2024] [authz_core:error] [pid 65329:tid 140715199817472] [client 172.69.194.206:28852] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:31:32.804424 2024] [authz_core:error] [pid 65328:tid 140714830702336] [client 172.71.254.154:34624] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:40:44.539675 2024] [authz_core:error] [pid 65329:tid 140715032028928] [client 162.158.238.47:19544] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:40:44.960703 2024] [authz_core:error] [pid 65329:tid 140715040421632] [client 162.158.239.49:19002] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:41:25.087132 2024] [authz_core:error] [pid 65329:tid 140715317249792] [client 172.70.207.166:41270] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:43:21.993072 2024] [authz_core:error] [pid 65329:tid 140715421558528] [client 172.71.103.88:38580] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:43:22.224420 2024] [authz_core:error] [pid 65328:tid 140715023636224] [client 172.69.7.29:35558] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:43:22.271541 2024] [authz_core:error] [pid 65329:tid 140715073992448] [client 172.71.182.181:56614] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:43:22.380438 2024] [authz_core:error] [pid 65329:tid 140715174639360] [client 172.70.178.14:35232] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:44:14.817786 2024] [authz_core:error] [pid 65328:tid 140714654553856] [client 172.71.254.102:17812] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:47:26.594853 2024] [authz_core:error] [pid 65329:tid 140715157853952] [client 172.69.164.168:29386] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:47:27.125406 2024] [authz_core:error] [pid 65329:tid 140715300464384] [client 172.69.164.152:53562] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain3.com
[Sat Jan 20 05:47:28.144867 2024] [mpm_event:notice] [pid 65327:tid 140715432307776] AH00491: caught SIGTERM, shutting down
[Sat Jan 20 05:47:28.222571 2024] [mpm_event:notice] [pid 65855:tid 139922688388160] AH00489: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Sat Jan 20 05:47:28.222697 2024] [core:notice] [pid 65855:tid 139922688388160] AH00094: Command line: '/usr/sbin/apache2'
[Sat Jan 20 05:47:32.108686 2024] [authz_core:error] [pid 65857:tid 139922526668544] [client 172.69.181.131:60948] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:47:32.380674 2024] [authz_core:error] [pid 65857:tid 139922518275840] [client 172.69.181.131:60948] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain1.com
[Sat Jan 20 05:48:16.047321 2024] [authz_core:error] [pid 65857:tid 139922451134208] [client 172.69.181.131:19966] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:48:16.270355 2024] [authz_core:error] [pid 65857:tid 139922425956096] [client 172.69.181.131:19966] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain1.com
[Sat Jan 20 05:48:22.513932 2024] [authz_core:error] [pid 65856:tid 139922585417472] [client 172.69.181.137:44522] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:48:22.944881 2024] [authz_core:error] [pid 65857:tid 139922409170688] [client 172.69.181.149:12368] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain2.com
[Sat Jan 20 05:49:19.922046 2024] [mpm_event:notice] [pid 65855:tid 139922688388160] AH00491: caught SIGTERM, shutting down
[Sat Jan 20 05:49:19.999403 2024] [mpm_event:notice] [pid 65963:tid 139849174543424] AH00489: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Sat Jan 20 05:49:19.999511 2024] [core:notice] [pid 65963:tid 139849174543424] AH00094: Command line: '/usr/sbin/apache2'
[Sat Jan 20 05:52:15.023931 2024] [mpm_event:notice] [pid 65963:tid 139849174543424] AH00491: caught SIGTERM, shutting down
[Sat Jan 20 05:52:15.231547 2024] [mpm_event:notice] [pid 66069:tid 140536332024896] AH00489: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Sat Jan 20 05:52:15.231683 2024] [core:notice] [pid 66069:tid 140536332024896] AH00094: Command line: '/usr/sbin/apache2'
[Sat Jan 20 05:52:25.839966 2024] [mpm_event:notice] [pid 66069:tid 140536332024896] AH00491: caught SIGTERM, shutting down
[Sat Jan 20 05:52:26.070471 2024] [mpm_event:notice] [pid 66153:tid 139731082521664] AH00489: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Sat Jan 20 05:52:26.070705 2024] [core:notice] [pid 66153:tid 139731082521664] AH00094: Command line: '/usr/sbin/apache2'
[Sat Jan 20 05:52:43.844826 2024] [authz_core:error] [pid 66155:tid 139731071772416] [client 172.69.181.139:62148] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:52:44.274941 2024] [authz_core:error] [pid 66155:tid 139730989610752] [client 172.69.181.130:45990] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain1.com
[Sat Jan 20 05:52:44.891464 2024] [authz_core:error] [pid 66155:tid 139730972825344] [client 172.69.181.139:62148] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:52:45.118771 2024] [authz_core:error] [pid 66155:tid 139730964432640] [client 172.69.181.130:45990] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain1.com
[Sat Jan 20 05:53:17.086487 2024] [authz_core:error] [pid 66155:tid 139730427561728] [client 172.71.222.201:29856] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:58:02.936833 2024] [authz_core:error] [pid 66154:tid 139731071772416] [client 185.224.128.191:49270] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:58:41.227505 2024] [authz_core:error] [pid 66154:tid 139730855393024] [client 172.69.181.136:41416] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:58:41.727218 2024] [authz_core:error] [pid 66155:tid 139730410776320] [client 172.69.181.131:59504] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain1.com
[Sat Jan 20 05:59:27.457990 2024] [authz_core:error] [pid 66154:tid 139730972825344] [client 172.69.181.131:26426] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:59:27.731487 2024] [authz_core:error] [pid 66154:tid 139730964432640] [client 172.69.181.131:26426] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain1.com
[Sat Jan 20 05:59:28.641890 2024] [authz_core:error] [pid 66154:tid 139730956039936] [client 172.69.181.131:26426] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 05:59:28.872481 2024] [authz_core:error] [pid 66154:tid 139730368845568] [client 172.69.181.131:26426] AH01630: client denied by server configuration: /etc/apache2/var, referer: mydomain1.com
[Sat Jan 20 06:01:35.666679 2024] [authz_core:error] [pid 66154:tid 139730343667456] [client 162.158.129.17:17478] AH01630: client denied by server configuration: /etc/apache2/var
[Sat Jan 20 06:01:53.605992 2024] [authz_core:error] [pid 66154:tid 139730326882048] [client 172.71.31.143:32380] AH01630: client denied by server configuration: /etc/apache2/var
