Hello I use Datalife engine(DLE) but I have a problem with some functions. I have tested it locally and on another server as well and it works normally. When I checked the requirements for this CMS, I couldn't find some PHP extensions to install in aapanel. can someone help solve this problem ?
You need the following installed on the server software:
Apache 2.0 or above
PHP 8.0 or above
MySQL 5.5.3 or MariaDB 10.0 or above
PHP extensions:
Installed extension PHP zlib
Installed extension xml
Installed extension gd2
Installed extension curl
Installed extension mbstring
Installed extension fileinfo
The minimum size of RAM is 16 Megabytes.
aaPanel_Kern [proxy_fcgi:error] [pid 13358:tid 140454762985024] [remote 37.232.52.135:61567] AH01067: Failed to read FastCGI header, referer:
I have this error can you help me ?
    Hello, I suggest you check whether the php configuration is normal? This problem is usually caused by incorrect php configuration.
    makhara020
      makhara020
      Hello, it is recommended that you check whether multiple identical extension configurations are configured at the same time.
