When I run in the terminal
root@hospedai:/home/ti# curl --tlsv1.2 https://agoracariri.com.br/wp-json/wp/v2/types/post?context=editcurl: (35) error:1425F102:SSL routines:ssl_choose_client_version:unsupported protocol
Informações:
Ubuntu: 20.04
Curl version: 7.68.0 OpenSSL/1.1.1f
This has prevented my Wordpress sites from performing functions such as API Reset, for example.
What have I tried?
sudo apt-get update
sudo apt-get install --only-upgrade curl
But without success. @aaPanel_Jose @aaPanel_Kern
If you could access my dashboard to check, I would appreciate it.
