UfukCH Hello friends, I set up webmail in Aapanel, everything is ok but there is a problem. COMMUNICATION WITH IMAP SERVER COULD NOT BE ESTABLISHED
aaPanel_Kern UfukCH Hello, what message do you get when communication is not possible? Are the relevant ports listening? Whether to configure SSL
UfukCH I solved the problem, but the only problem is that others are sending me e-mails, I cannot send e-mails, the e-mails are not sent to the other party.
henriquelucas UfukCH No doors blocked? Do you use your own infrastructure or did you hire one like AWS, Google Cloud, Vultr or something like that? This appears to me to be a blocked port.
