aaPanel_Kern Hello, it is recommended that you check whether the website is set up to use http to access the website. It is recommended that you check the website program configuration. ihzahabibi
ihzahabibi aaPanel_Kern If I use https how do I do it? because if I use http I can't edit the website
aaPanel_Kern It is recommended that you search how to modify the backend address in wordpress https://kinsta.com/knowledgebase/wordpress-change-url/#:~:text=Change%20WordPress%20URL%20via%20the%20Admin%20Dashboard,-The%20first%20and&text=In%20the%20admin%20menu%2C%20go,of%20your%20WordPress%20core%20files. ihzahabibi
aaPanel_Kern Please check your configuration yourself. Check whether using CDN, forcing HTTPS, etc. will cause too many redirects ihzahabibi
