Hello, In my aapanel i have installed Nginx 1.17, MySQL5.6 and Php7.4 and also installed redis extention from Php7.4. My redis is keep stopping automatically after several hours and i need to manually start it again which is causing my website goes offline. How can i fix this issue and where can i find the error logs that cause redis to stop automatically. Please help me to fix the issue.
My vps 2vcpu, 2GB ram and 50GB disk
    aaP_uby777881
    This seems to be caused by low hardware configuration. It is recommended that you check whether it is shut down by the system.
    Also set the redis configuration settings to use memory
