Emily95 Hello I installed Roundcube using OneClick but when I try to access I got this message Any help please
aaPanel_Kern Emily95 Hi check if the configuration of roundcube is correct? Replace 135roundcubemail.com with your domain name Modify this file: /www/wwwroot/135roundcubemail.com/config/config.inc.php Add the following: $config['enable_installer'] = true; Then browser access: http://135roundcubemail.com/installer/?_step=1 Final test setup
Emily95 thank you for quick response here I add the function on config file , but I have red error I think on installation here 2 screenshots
aaPanel_Kern Hello, follow the prompts to deal with the missing dependent extensions. You can find the relevant php from the app store to install the extensions. Emily95
