I added those parameters.
screenshot that the ping is working.
rebooted the server, rebooted the panel.
I also rebooted the panel through the console and cleared the console cache bt 1 and bt 9.
Basically the error remains, and although I see another error now, but there are 2 times just one after the other. You can see it in the console. There are two errors.
500 (INTERNAL SERVER ERROR)
It's sad that they can't solve the problem for more than 24 hours.
p.s. I have aapanel on 3 vps. On one of them there is no error. On 2 of them there is a problem.
I also changed another browser, put the ssl option on the panel address, nothing helped(
The main problem where i installed the panel yesterday, but can't put anything else. I.e. put php, litespeed and other, can't.
