requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
REQUEST_DATE: 2024-01-06 19:56:13
PAN_VERSION: 6.8.31
OS_VERSION: CentOS 7.9.2009 x86_64(Py3.7.9)
REQUEST_URI: POST /ajax?action=get_pay_type
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36
File "/www/server/panel/BTPanel/init.py", line 1812, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1764, in run
File "/www/server/panel/class/ajax.py", line 1637, in get_pay_type
plugin_list = plu_panel.get_cloud_list()
File "/www/server/panel/class/panelPlugin.py", line 366, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 115, in post
return request("post", url, data=data, json=json, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 59, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 589, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 519, in send
回溯(最近一次调用最后):文件“/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py”,第175行,在new_conn(self.dns_host,self.port)中,self.timeout,extra_kw 文件“/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py”,第72行,在create_connection中用于socket.getaddrinfo中的资源(主机、端口、系列、socket.SOCK_STREAM):文件“/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/socketcommon.py”,第 247 行,在 getaddrinfo addrlist = get_hub() 中。 resolver.getaddrinfo(host, port, family, type, proto, flags) 文件“/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/resolver/thread.py”,第 63 行,位于getaddrinfo return self.pool.apply(socket.getaddrinfo, args, kwargs) 文件“/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/pool.py”,第 161 行,在 apply return 中self.spawn(func, args, **kwds).get() 文件“src/gevent/event.py”,第 306 行,在 gevent.gevent_cevent.AsyncResult.get 文件“src/gevent/event.py”中,第 336 行,在 gevent.gevent_cevent.AsyncResult.get 文件“src/gevent/event.py”中,第 324 行,在 gevent._gevent_cevent.AsyncResult.get 文件“src/gevent/event.py”中,第 304 行,在 gevent 中。 gevent_cevent.AsyncResult.raise_exception 文件“/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/_compat.py”,第 65 行,在 reraise 中提高 value.with_traceback(tb) 文件“/www/ server/panel/pyenv/lib/python3.7/site-packages/gevent/threadpool.py”,第 167 行,在 __run_task thread_result.set(func(args, **kwargs)) socket.gaierror: [Errno -2 ] 名称或服务未知 在处理上述异常期间,发生了另一个异常: Traceback (最近一次调用最后): File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py”,第 721 行,在 urlopen chunked=chunked,文件“/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py”,第 403 行,在 make_request self.validate_conn(conn )文件“/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py”,第1053行,在validate_conn conn.connect()文件“/www/server/panel/pyenv/ lib/python3.7/site-packages/urllib3/connection.py”,第 363 行,在连接 self.sock = conn = self.new_conn() 文件“/www/server/panel/pyenv/lib/python3.7/ site-packages/urllib3/connection.py”,第 187 行,在 _new_conn self 中,“无法建立新连接:%s” % e urllib3.exceptions。NewConnectionError: : 无法建立新连接: [Errno -2] 名称或服务未知
在处理上述异常的过程中,又出现了一个异常:
回溯(最近一次调用最后一次):
文件“/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py”,第 497 行,发送
分块=分块,
文件“/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py”,第 799 行,位于 urlopen
方法、url、error=e、pool=self、stacktrace=sys.exc_info()[2]
文件“/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py”,第 592 行,增量
引发 MaxRetryError(_pool, url, error 或 ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): url 超出最大重试次数:/api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info= %7B%7D(由 NewConnectionError 引起(':无法建立新连接:[Errno -2] 名称或服务未知'))
回溯(最近一次调用最后一次):
文件“/www/server/panel/BTPanel/init.py”,第 1812 行,在 publicObject 中
返回 run_exec().run(toObject, defs, get)
文件“/www/server/panel/BTPanel/init.py”,第 1764 行,运行中
结果 = getattr(toObject,get.action)(get)
文件“/www/server/panel/class/ajax.py”,第 1637 行,在 get_pay_type 中
文件“/www/server/panel/class/panelPlugin.py”,第 366 行,位于 get_cloud_list
文件“/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py”,第 115 行,在帖子中
返回请求(“post”,url,data=data,json=json,**kwargs)
文件“/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py”,第 59 行,请求中
返回 session.request(method=method, url=url, **kwargs)
文件“/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py”,第 589 行,请求中
文件“/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py”,第 703 行,发送
r = 适配器.send(请求, **kwargs)
文件“/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py”,第 519 行,发送
引发连接错误(e,请求=请求)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): 超过最大重试次数,网址:/api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info= %7B%7D(由 NewConnectionError 引起(':无法建立新连接:[Errno -2] 名称或服务未知'))
