aaPanel_Kern Hello, did you add the configuration under the Configuration file? Extension=imagick.so is caused by duplication. It works normally after adding the # comment.
aaPanel_Kern It is recommended that you delete redundant configurations and restart php aaP_ramonmariano
aaP_ramonmariano aaPanel_Kern ok deleted, but now another error appears, saying that gd is not installed, but it is as you can see in the second image.
aaP_ramonmariano aaPanel_Kern I tried closed and open, both still have the same error, I was showing you.
