aaP_abdillah_pandu0 Hy can you suggest im running whatsapp server a node project, it working well buat often suddenly stop, can you give me solution ?
aaPanel_Kern The panel only starts once. If it is closed by the system or the program itself is closed due to problems, it will be closed. Use supervisor to check whether it is closed. If it is closed, it will start automatically. aaP_abdillah_pandu0
aaP_abdillah_pandu0 aaPanel_Kern dan yang saya lakukan hanya install the extension ? is there any more step by step to prevent my node project stop sir ?
aaPanel_Kern You need to install the relevant extensions yourself, there are no more methods at the moment aaP_abdillah_pandu0
aaP_abdillah_pandu0 aaPanel_Kern no i asking how to prevent my node project stopping frequently and you sugesting to install supervisor, i've installed it after your recommendation. and whats next ?
