aaPanel_Kern aaP_syedsabahathussain Hello, check if the configuration of roundcube is correct? Replace 135roundcubemail.com with your domain name Modify this file: /www/wwwroot/135roundcubemail.com/config/config.inc.php Add the following: $config['enable_installer'] = true; Then browser access: http://135roundcubemail.com/installer/?_step=1 Final test setup
aaP_syedsabahathussain aaPanel_Kern Yes everything thing is perfect but not able to send mail using port 25 or any other port
aaPanel_Kern Is it possible to connect to the mail server and send emails while testing Roundcube? To send using the mail server interface, you must use port 25 to send. aaP_syedsabahathussain
aaPanel_Kern aaP_syedsabahathussain Hello, would you like to check if the server's network is normal?
