aaP_evanv25 SSL TLS 1.2 I have my config for my website SSLProtocol TLSv1.2 TLSv1.3 restarted apache and mysql but when i check for tls 1.2 it still says disabled on checker![upl-image-preview url=https://www.aapanel.com/forum/assets/files/2023-12-31/1703980941-262399-screenshot-2023-12-30-180112.png]
aaPanel_Kern Hello, is the problem solved? TLS1.2 is enabled by default. Have you modified the configuration file? aaP_evanv25
aaP_evanv25 aaPanel_Kern i reissued lets encrypt and it fixed it. But i keep having issues with WHMCS using apache and php 7.4, it gets slow then throws error 503
aaP_evanv25 [proxy_fcgi:error] [pid 6401:tid 140070767556352] (104)Connection reset by peer: [remote 70.94.179.182:55224] AH01075: Error dispatching request to : , referer: https://xxxxx.com/?_task=mail&_action=compose&_id=2005921451659331c550843
