aaPanel_Kern aaP_olaniyi Hello, this is automatically generated by mysql. It is recommended to keep it if your space allows, otherwise you can reduce the save date, or close it
aaP_olaniyi aaPanel_Kern how can I close it I don’t save space on my server as my website keep going offline how can I stop it from generating the files
Stealth aaPanel_Kern Yeah, we need close it. I saying this half year. Only log eat all VPS space... Thats not normal, before half year no problems like this (or in other panel like CyberPanel or Plesk).
aaPanel_Kern Hello, it is not recommended to close it. It is recommended to use phpmyadmin to check the content of the file. You can try aapanel to upgrade to the test version and then close the log. Stealth aaP_olaniyi
Stealth aaPanel_Kern But we dont know where to check it. In database but where? Database are same size.
