aaP_ramonmariano I have a second HD already mounted, how do I move the Wordpress sites that I moved and changed the location in the settings for the new HD to work? Error 500 is showing.
aaP_ramonmariano ERROR LOG Project-Id-Version: PO-Revision-Date: 2022-01-05 10:16+0800 Last-Translator: Language-Team: Language: en MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit Plural-Forms: nplurals=1; plural=0; Generated-By: pygettext.py 1.5 X-Generator: Poedit 3.0.1
aaP_ramonmariano I deleted the user.ini file and activated it again, and now another error is appearing: XCEPTION FOUND Message: unable to write file /mnt/HC_Volume_100213855/...
aaPanel_Kern Hello, I suggest you check whether the permissions in the directory are 755/www ? Also check if this can write to a file using? aaP_ramonmariano
