Hai, I want to run my node application on aapanel
this is my setting
when accessing the domain api1.jadidalmagribi.com,
error 400
need help please
    You need to add the 1000 port, or don't add the port when remapping. Is it possible to solve this problem?
    almagribi
    Thank you it solve, I dont add the port when remapping,
    the other problem, .env file can be read by aapanel, can you help me with this
      It is recommended that you describe the problem in detail, aapanel can read all files in the system
      almagribi
      For the first time, node app runs well, but there is a problem with nginx
      nginx cannot start due to the binding error
        Hello, you no longer need to use project port: 2000 when using mapping
        Just add the domain name directly, and then access using the domain name will reverse proxy to the project
        almagribi
