aaP_antonio_etec_inf5 Hi, help me please: After bt 16: # bt 1 =============================================== EXECUTING =============================================== Stopping Bt-Tasks... done Stopping Bt-Panel... done /etc/init.d/bt: line 117: lsof: command not found /etc/init.d/bt: line 168: lsof: command not found Starting Bt-Panel............failed ------------------------------------------------------ nohup: failed to run command ‘/www/server/panel/BT-Panel’: Permission denied nohup: failed to run command ‘/www/server/panel/BT-Panel’: Permission denied nohup: failed to run command ‘/www/server/panel/BT-Panel’: Permission denied ------------------------------------------------------ Error: BT-Panel service startup failed. done Starting Bt-Tasks... failed ------------------------------------------------------ nohup: failed to run command ‘/www/server/panel/BT-Task’: Permission denied nohup: failed to run command ‘/www/server/panel/BT-Task’: Permission denied nohup: failed to run command ‘/www/server/panel/BT-Task’: Permission denied ------------------------------------------------------ Error: BT-Task service startup failed. # ls -la /www/server/panel/BT-Task -rwx------ 1 root root 516 Dec 21 20:02 /www/server/panel/BT-Task I uninstall the lsof, but it was working without it.
aaPanel_Kern aaP_antonio_etec_inf5 Hello, please use root privileges to execute the command apt install lsof -y || yum install lsof -y
aaPanel_Kern There is this problem under docker. It is recommended that you use VPS for installation. aaP_antonio_etec_inf5
aaP_antonio_etec_inf5 if I install lsof it will stuck and it will not start like this: Stopping Bt-Tasks... done Stopping Bt-Panel... done with no return, or maybe after more than one hour. but it isn't the problem, the problem is permission
aaP_antonio_etec_inf5 hi, the docker is working fine, it was just persist this folder: /www/server/panel/vhost my path was missing for a mistake.
