aaPanel_Kern Hello, I suggest you check what is occupying the CPU on the monitoring interface. ratebalkhawaja
izsurya After updating the latest version of aaPanel, I'm also facing a 100% CPU load, before the latest update my average CPU usage was ~ 2% and now it's 100% many times, reason PHP-FPM. @aaPanel_Kern can you resolve this issue?
aaPanel_Kern Hello, this is related to your website. I suggest you check whether it has been attacked? izsurya
aaPanel_Kern Hello, try to manually execute the command to install the dependencies, and then install php. Is it normal? debian: sudo apt-get install libiconv-dev centos: sudo yum install libiconv-devel izsurya
aaPanel_Kern When you put the mouse over it, what process shows the CPU occupied by it? Is it being attacked by cc? ratebalkhawaja
