aaP_sagarkumarsahu60 i am little confused where is file manager and all the thhings which is available in normal aapanel ?
aaP_bybihhi How to change the language of aaWAF, after FIX the language became Chinese. And how to change the panel time?
aaP_bybihhi aaPanel_Kern I didn't do any commands, just clicked the FIX button and then the language became Chinese.
aaPanel_Kern aaP_bybihhi Execute command to repair curl -k https://node.aapanel.com/cloudwaf_en/scripts/update_cloudwaf_en.sh |bash aaP_bybihhi
Mrqz Hello, We was successfully install aaWAF Free in offline mode. Now we want to restrict working area just to one region (not China), are system have requirement to full access to internet area? May be system have some syncing process or they do license checking? Thank you
psp50 is aapanel and aawaf totaly different ? can I use Aapanel and Aawaf on the same server? currently, i am using Aapanel, did I required to use aawaf? I am a student, i am not an expert in it please guide me in detail. I am confused.
Mrqz Hello, Thank You for previous response to my question. If I may ask a few more questions: Current english version of aaWAF is 1.0, chinese version already 2.8 or 2.9, have You plan publish a new version of english realese? Map in version 1.0 not working, is it way to fix this mannualy without waiting update? And my last question regarding IP blacklist, via Web UI we have opurtunity to import list of IPs or subnets, but we want to automate this process. Are this blacklist stored in DB? Can we work with the database ourselves and import the necessary data into it directly? Thank You
Mrqz Also we see that waf system all time send some data to IP 42.157.129.47 and take long time connections with this IPs - 123.183.224.10 and 58.221.23.182. Will be nice just from security point of view to understand the nature of these connections. Thank You!
aaPanel_Kern Hello, there is currently no information to publish The map is a known issue that has been recorded and needs to be fixed. Blacklists can only be imported via the Web UI The program will communicate with the server regularly every day and only collect the number of program activations. 123.183.224.10 and 58.221.23.182 are not our services. I’m not sure where the IP addresses are. Mrqz
Mrqz Dear @aaPanel_Kern what are You mean under “program activations”? If access to 42.157.129.47 restricted by firewall, this will not affect to the correct work of the program? And just for informaton I discovered that server must have preinstalled “ipset”! Command that checks pre-installed dependencies, which are mentioned in installation tutorial not check are this tool installed or not.
aaP_info_philongland aaPanel_Kern How to renew free SSL certificate on aWAF? For websites using aapanel, you will be issued a free SSL certificate, but currently using aWAF's IP, the SSL cannot be renewed automatically. Is there any solution to this problem?
aaPanel_Kern Hello, it is recommended that you copy the certificate to aawaf for configuration. This function is not available at the moment. aaP_info_philongland
yclywz41 aaPanel_Kern "I am wondering whether there is any plan for AAWAF to provide API support, particularly considering an integration similar to AAPanel?
hungcp Hello, In "Back-to-origin configuration" screen, how to add a node by domain name instead of ip address?
