aaP_gorgeious1 Hello. Kindly please help me. Yesterday, someone added some another site in my aapenal and after that i am unable to open it. Please could you please help to restore my previous setting.
aaPanel_Kern Hello, you are unable to access aapanel? Please check if you are using the full link to access the panel you can view bt 14 using the command aaP_gorgeious1
aaP_gorgeious1 aaPanel_Kern yes im using teh full link.. is it any way that your team can restore my previous setting?
aaPanel_Kern I suggest you describe the problem in detail. Can you provide more information? For example: Is a domain name bound to the panel? Use bt 12 to cancel aaP_gorgeious1
