Hey, Support:
I recently configured Mastodon on one of my 4 Cores 8G Ubuntu 22.04 servers (refer to the following tutorial: https://cn.linux-console.net/?p=3602).
When configuring Mastodon with aapanel, Nginx gets stuck in an ERR_TOO_MANY_REDIRECTS loop.
I also submit ISSUES on Github (https://github.com/mastodon/mastodon/issues/27824).
I still can't solve the problem of reporting error ERR_TOO_MANY_REDIRECTS after entering the site, can you please help me to analyze the specific error?
Below is my Nginx configuration file:
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream backend {
server 127.0.0.1:3000 fail_timeout=0;
upstream streaming {
server 127.0.0.1:4000 fail_timeout=0;
proxy_cache_path /var/cache/nginx levels=1:2 keys_zone=CACHE:10m inactive=7d max_size=1g;
server {
listen 80;
listen [::]:80;
server_name starry.polarissmusic.cn;
root /var/www/mastodon/public;
location /.well-known/acme-challenge/ { allow all; }
location / { return 301 https://$host$request_uri; }
server {
# listen 443 ssl http2;
# listen [::]:443 ssl http2;
# ssl_protocols TLSv1.2 TLSv1.3;
# ssl_ciphers HIGH:!MEDIUM:!LOW:!aNULL:!NULL:!SHA;
# ssl_prefer_server_ciphers on;
# ssl_session_cache shared:SSL:10m;
# ssl_session_tickets off;
# Uncomment these lines once you acquire a certificate:
# ssl_certificate /etc/letsencrypt/live/starry.polarissmusic.cn/fullchain.pem;
# ssl_certificate_key /etc/letsencrypt/live/starry.polarissmusic.cn/privkey.pem;
keepalive_timeout 70;
sendfile on;
client_max_body_size 80m;
gzip on;
gzip_disable "msie6";
gzip_vary on;
gzip_proxied any;
gzip_comp_level 6;
gzip_buffers 16 8k;
gzip_http_version 1.1;
gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript image/svg+xml image/x-icon;
location / {
try_files $uri @proxy;
# If Docker is used for deployment and Rails serves static files,
# then needed must replace line `try_files $uri =404;` with `try_files $uri @proxy;`.
location = /sw.js {
add_header Cache-Control "public, max-age=604800, must-revalidate";
add_header Strict-Transport-Security "max-age=63072000; includeSubDomains";
location ~ ^/assets/ {
add_header Cache-Control "public, max-age=2419200, must-revalidate";
location ~ ^/avatars/ {
location ~ ^/emoji/ {
location ~ ^/headers/ {
location ~ ^/packs/ {
location ~ ^/shortcuts/ {
location ~ ^/sounds/ {
location ~ ^/system/ {
add_header Cache-Control "public, max-age=2419200, immutable";
location ^~ /api/v1/streaming {
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header Proxy "";
proxy_pass http://streaming;
proxy_buffering off;
proxy_redirect off;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
tcp_nodelay on;
location @proxy {
proxy_pass_header Server;
proxy_pass http://backend;
proxy_buffering on;
proxy_redirect off;
proxy_cache CACHE;
proxy_cache_valid 200 7d;
proxy_cache_valid 410 24h;
proxy_cache_use_stale error timeout updating http_500 http_502 http_503 http_504;
add_header X-Cached $upstream_cache_status;
tcp_nodelay on;
error_page 404 500 501 502 503 504 /500.html;
Best
PolarisS
