yazan Hello, I can't start nodeJs project on server. Note that there are no projects working on the same port, and I was trying before with the same port, but it was giving me an error that node project cannot start.
aaPanel_Kern Hello, it is recommended that you use the command line to check whether the relevant port is in use netstat -tulnp|grep 3101 yazan
aaPanel_Kern Hello, the screenshot shows that it has been used. I suggest you check what program is being used? Or change other ports? yazan
yazan aaPanel_Kern Hello, I've created a node project on the same port in the past, and I've deleted it. I think the deleted project is still working on the same port, but the node project panel in the websites nav bar shows that there are no project created. What is the probelm?
aaPanel_Kern It may be that the panel cannot obtain the process ID normally. It is recommended that you check to manually kill the process and then deploy it normally. yazan
yazan aaPanel_Kern I tried to change the port, and it works, but the project is not starting: What is the problem ?
