File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 170, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 73, in create_connection
File "src/gevent/event.py", line 306, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 336, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 324, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 304, in gevent.gevent_cevent.AsyncResult.raise_exception
socket.gaierror: [Errno -2] Name or service not known
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 382, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1010, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 353, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 182, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -2] Name or service not known
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 573, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
File "/www/server/panel/BTPanel/init.py", line 1814, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1766, in run
File "class/ajax.py", line 1639, in get_pay_type
plugin_list = plu_panel.get_cloud_list()
File "class/panelPlugin.py", line 366, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 119, in post
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
