Lucifer I got a [A record parsing fail] error when i add my 1th domain to email server, I check the A record's IP & setting, everything should be correct, , but this fail to add domain, any solution to solve this problem, thanks Platform : Ubuntu 20.04.4 LTS x86_64(Py3.7.9) Hosting Provider : digitalocean Mail server v 4.6 A RECORD is pointed correctly what i did several times RESTART SERVER + RESTART PANEL + DELETE MAIL SERVER APP + INSTALL MAIL SERVER APP DELETE A RECORD FROM DG +(ADD) nothing work
Lucifer aaPanel_Kern well -> A Parse is working with himself but now since yestrday to now MX RECORD Wont to work
aaPanel_Kern Hello, I suggest you check if the mx record points to the server IP https://dnschecker.org/all-dns-records-of-domain.php Lucifer
aaPanel_Kern Multiple mx records are not supported Only use one mx record If the mail server can receive and send mail normally, just ignore it. Lucifer
