I'm getting this error during install nginx from appstore
what should I do
Length: 14477 (14K) [application/octet-stream]
Saving to: ‘nginx-dav-ext-module-3.0.0.tar.gz’
0K .......... .... 100% 389M=0s
2023-11-17 13:01:42 (389 MB/s) - ‘nginx-dav-ext-module-3.0.0.tar.gz’ saved [14477/14477]
nginx-dav-ext-module-3.0.0/
nginx-dav-ext-module-3.0.0/LICENSE
nginx-dav-ext-module-3.0.0/README.rst
nginx-dav-ext-module-3.0.0/config
nginx-dav-ext-module-3.0.0/ngx_http_dav_ext_module.c
nginx-dav-ext-module-3.0.0/t/
nginx-dav-ext-module-3.0.0/t/dav_ext.t
--2023-11-17 13:01:42-- https://dg2.bt.cn/src/ngx_http_substitutions_filter_module-master.zip
Resolving dg2.bt.cn (dg2.bt.cn)... 103.179.243.14, 2001:19f0:7001:54fc:5400:2ff:fe9b:97f9
Connecting to dg2.bt.cn (dg2.bt.cn)|103.179.243.14|:443... connected.
Length: 120845 (118K) [application/zip]
Saving to: ‘ngx_http_substitutions_filter_module-master.zip’
0K .......... .......... .......... .......... .......... 42% 258K 0s
50K .......... .......... .......... .......... .......... 84% 259K 0s
100K .......... ........ 100% 209M=0.4s
2023-11-17 13:01:43 (305 KB/s) - ‘ngx_http_substitutions_filter_module-master.zip’ saved [120845/120845]
Archive: ngx_http_substitutions_filter_module-master.zip
e12e965ac1837ca709709f9a26f572a54d83430e
creating: ngx_http_substitutions_filter_module-master/
extracting: ngx_http_substitutions_filter_module-master/.gitignore
inflating: ngx_http_substitutions_filter_module-master/CHANGES
inflating: ngx_http_substitutions_filter_module-master/README
inflating: ngx_http_substitutions_filter_module-master/config
creating: ngx_http_substitutions_filter_module-master/doc/
inflating: ngx_http_substitutions_filter_module-master/doc/README.google_code_home_page.wiki
inflating: ngx_http_substitutions_filter_module-master/doc/README.html
inflating: ngx_http_substitutions_filter_module-master/doc/README.wiki
inflating: ngx_http_substitutions_filter_module-master/ngx_http_subs_filter_module.c
creating: ngx_http_substitutions_filter_module-master/test/
inflating: ngx_http_substitutions_filter_module-master/test/README
creating: ngx_http_substitutions_filter_module-master/test/inc/
creating: ngx_http_substitutions_filter_module-master/test/inc/Module/
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/AutoInstall.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install.pm
creating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/AutoInstall.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/Base.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/Can.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/Fetch.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/Include.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/Makefile.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/Metadata.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/TestBase.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/Win32.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Module/Install/WriteAll.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Spiffy.pm
creating: ngx_http_substitutions_filter_module-master/test/inc/Test/
inflating: ngx_http_substitutions_filter_module-master/test/inc/Test/Base.pm
creating: ngx_http_substitutions_filter_module-master/test/inc/Test/Base/
inflating: ngx_http_substitutions_filter_module-master/test/inc/Test/Base/Filter.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Test/Builder.pm
creating: ngx_http_substitutions_filter_module-master/test/inc/Test/Builder/
inflating: ngx_http_substitutions_filter_module-master/test/inc/Test/Builder/Module.pm
inflating: ngx_http_substitutions_filter_module-master/test/inc/Test/More.pm
creating: ngx_http_substitutions_filter_module-master/test/lib/
creating: ngx_http_substitutions_filter_module-master/test/lib/Test/
inflating: ngx_http_substitutions_filter_module-master/test/lib/Test/Nginx.pm
creating: ngx_http_substitutions_filter_module-master/test/lib/Test/Nginx/
inflating: ngx_http_substitutions_filter_module-master/test/lib/Test/Nginx/LWP.pm
inflating: ngx_http_substitutions_filter_module-master/test/lib/Test/Nginx/Socket.pm
inflating: ngx_http_substitutions_filter_module-master/test/lib/Test/Nginx/Util.pm
creating: ngx_http_substitutions_filter_module-master/test/t/
inflating: ngx_http_substitutions_filter_module-master/test/t/subs.t
inflating: ngx_http_substitutions_filter_module-master/test/t/subs_capture.t
inflating: ngx_http_substitutions_filter_module-master/test/t/subs_fix_string.t
inflating: ngx_http_substitutions_filter_module-master/test/t/subs_none_regex.t
inflating: ngx_http_substitutions_filter_module-master/test/t/subs_regex.t
inflating: ngx_http_substitutions_filter_module-master/test/t/subs_types.t
inflating: ngx_http_substitutions_filter_module-master/test/test.sh
creating: ngx_http_substitutions_filter_module-master/util/
inflating: ngx_http_substitutions_filter_module-master/util/update-readme.sh
inflating: ngx_http_substitutions_filter_module-master/util/wiki2google_code_homepage.pl
inflating: ngx_http_substitutions_filter_module-master/util/wiki2pod.pl
cat: /www/server/panel/install/nginx/config.pl: No such file or directory
checking for OS
- Linux 5.4.17-2136.325.5.el8uek.aarch64 aarch64
checking for C compiler ... found
- using GNU C compiler
- gcc version: 8.5.0 20210514 (Red Hat 8.5.0-18.0.6) (GCC)
checking for gcc -pipe switch ... found
checking for --with-ld-opt="-ljemalloc" ... found
checking for -Wl,-E switch ... found
checking for gcc builtin atomic operations ...auto/feature: line 52: 1212069 Segmentation fault (core dumped) /bin/sh -c $NGX_AUTOTEST >> $NGX_AUTOCONF_ERR 2>&1
found but is not working
checking for C99 variadic macros ...auto/feature: line 52: 1212088 Segmentation fault (core dumped) /bin/sh -c $NGX_AUTOTEST >> $NGX_AUTOCONF_ERR 2>&1
checking for gcc variadic macros ...auto/feature: line 52: 1212108 Segmentation fault (core dumped) /bin/sh -c $NGX_AUTOTEST >> $NGX_AUTOCONF_ERR 2>&1
checking for gcc builtin 64 bit byteswap ... found
checking for unistd.h ... found
checking for inttypes.h ... found
checking for limits.h ... found
checking for sys/filio.h ... not found
checking for sys/param.h ... found
checking for sys/mount.h ... found
checking for sys/statvfs.h ... found
checking for crypt.h ... found
checking for Linux specific features
checking for epoll ...auto/feature: line 52: 1212233 Segmentation fault (core dumped) /bin/sh -c $NGX_AUTOTEST >> $NGX_AUTOCONF_ERR 2>&1
checking for O_PATH ... found
checking for sendfile() ...auto/feature: line 52: 1212264 Segmentation fault (core dumped) /bin/sh -c $NGX_AUTOTEST >> $NGX_AUTOCONF_ERR 2>&1
checking for sendfile64() ...auto/feature: line 52: 1212283 Segmentation fault (core dumped) /bin/sh -c $NGX_AUTOTEST >> $NGX_AUTOCONF_ERR 2>&1
checking for sys/prctl.h ... found
checking for prctl(PR_SET_DUMPABLE) ...auto/feature: line 52: 1212314 Segmentation fault (core dumped) /bin/sh -c $NGX_AUTOTEST >> $NGX_AUTOCONF_ERR 2>&1
checking for prctl(PR_SET_KEEPCAPS) ...auto/feature: line 52: 1212334 Segmentation fault (core dumped) /bin/sh -c $NGX_AUTOTEST >> $NGX_AUTOCONF_ERR 2>&1
checking for capabilities ... found
checking for crypt_r() ... found
checking for sys/vfs.h ... found
checking for UDP_SEGMENT ... not found
checking for poll() ... found
checking for /dev/poll ... not found
checking for kqueue ... not found
checking for crypt() ... not found
checking for crypt() in libcrypt ... found
checking for F_READAHEAD ... not found
checking for posix_fadvise() ... found
checking for O_DIRECT ... found
checking for F_NOCACHE ... not found
checking for directio() ... not found
checking for statfs() ... found
checking for statvfs() ... found
checking for dlopen() ... not found
checking for dlopen() in libdl ... found
checking for sched_yield() ... found
checking for sched_setaffinity() ... found
checking for SO_SETFIB ... not found
checking for SO_REUSEPORT ... found
checking for SO_ACCEPTFILTER ... not found
checking for SO_BINDANY ... not found
checking for IP_TRANSPARENT ... found
checking for IP_BINDANY ... not found
checking for IP_BIND_ADDRESS_NO_PORT ... found
checking for IP_RECVDSTADDR ... not found
checking for IP_SENDSRCADDR ... not found
checking for IP_PKTINFO ... found
checking for IPV6_RECVPKTINFO ... found
checking for TCP_DEFER_ACCEPT ... found
checking for TCP_KEEPIDLE ... found
checking for TCP_FASTOPEN ... found
checking for TCP_INFO ... found
checking for accept4() ... found
checking for int size ... bytes
./configure: error: can not detect int size
make: *** No rule to make target 'build', needed by 'default'. Stop.
make: *** No rule to make target 'install'. Stop.
Red Hat Enterprise Linux release 8.8 (Ootpa)
Bit:64 Mem:23364M Core:4 gcc:8.5.0 cmake:3.20.2
ERROR: nginx-1.24.0 installation failed.
安装失败,请截图以上报错信息发帖至论坛www.bt.cn/bbs求助
或手机访问以下链接、扫码联系企业微信技术求助
帖子或企业微信注明企业版用户,将获得极速响应技术支持
