i just created a new project with wordpress Deploy in aapnel .
version i have on aapanel :
Aapanel Version : 6.8.32
PHP : 8.0
DB : Mysql 5.7.43
Nginx : 1.21.4
and i got this error :
requests.exceptions.ConnectionError: HTTPConnectionPool(host='wordpress.org', port=80): Max retries exceeded with url: /download/ (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -5] No address associated with hostname'))
this is the Traceback :
`Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 175, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 72, in create_connection
File "src/gevent/event.py", line 306, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 336, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 324, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 304, in gevent.gevent_cevent.AsyncResult.raise_exception
socket.gaierror: [Errno -5] No address associated with hostname
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 710, in urlopen
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 398, in make_request
conn.request(method, url, **httplib_request_kw)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 244, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1277, in request
self.send_request(method, url, body, headers, encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1323, in send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1272, in endheaders
self.send_output(message_body, encode_chunked=encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1032, in send_output
self.send(msg)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 972, in send
self.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 205, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 187, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -5] No address associated with hostname
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 498, in send
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 788, in urlopen
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 592, in increment
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='wordpress.org', port=80): Max retries exceeded with url: /download/ (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -5] No address associated with hostname'))
File "/www/server/panel/BTPanel/init.py", line 1812, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1764, in run
File "/www/server/panel/class/panelSite.py", line 6000, in is_update
return one_key_wp.one_key_wp().is_update(get)
File "/www/server/panel/class/one_key_wp.py", line 534, in is_update
online_v = self.get_wp_version_online()
File "/www/server/panel/class/one_key_wp.py", line 520, in get_wp_version_online
result = requests.get(url,headers=headers)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 73, in get
return request("get", url, params=params, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 59, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 587, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 701, in send
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 520, in send
requests.exceptions.ConnectionError: HTTPConnectionPool(host='wordpress.org', port=80): Max retries exceeded with url: /download/ (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -5] No address associated with hostname'))`
