IPv6 does not support PTR, it is recommended that you disable IPv6
Temporarily close ipv6 and execute the command:
sudo sysctl -w net.ipv6.conf.all.disable_ipv6=1
sudo sysctl -w net.ipv6.conf.default.disable_ipv6=1
sudo sysctl -w net.ipv6.conf.lo.disable_ipv6=1
Permanent
vim /etc/sysctl.conf
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
For the settings to take effect use:
sudo sysctl -p
Unable to send dkim headers
Prompt for permission issues:
systemctl restart rspamd
Faris
