WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
keyutils libnfsidmap2 nfs-common rpcbind
Suggested packages:
open-iscsi watchdog
The following NEW packages will be installed:
keyutils libnfsidmap2 nfs-common nfs-kernel-server rpcbind
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 494 kB of archives.
After this operation, 1566 kB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bullseye/main amd64 rpcbind amd64 1.2.5-9 [51.4 kB]
Get:2 http://deb.debian.org/debian bullseye/main amd64 keyutils amd64 1.6.1-2 [52.8 kB]
Get:3 http://deb.debian.org/debian bullseye/main amd64 libnfsidmap2 amd64 0.25-6 [32.6 kB]
Get:4 http://deb.debian.org/debian bullseye/main amd64 nfs-common amd64 1:1.3.4-6 [232 kB]
Get:5 http://deb.debian.org/debian bullseye/main amd64 nfs-kernel-server amd64 1:1.3.4-6 [125 kB]
apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct!
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_US:en",
LC_ALL = (unset),
LC_CTYPE = "C.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
dpkg-preconfigure: unable to re-open stdin: No such file or directory
Fetched 494 kB in 0s (1493 kB/s)
Selecting previously unselected package rpcbind.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 42322 files and directories currently installed.)
Preparing to unpack .../rpcbind_1.2.5-9_amd64.deb ...
Unpacking rpcbind (1.2.5-9) ...
Selecting previously unselected package keyutils.
Preparing to unpack .../keyutils_1.6.1-2_amd64.deb ...
Unpacking keyutils (1.6.1-2) ...
Selecting previously unselected package libnfsidmap2:amd64.
Preparing to unpack .../libnfsidmap2_0.25-6_amd64.deb ...
Unpacking libnfsidmap2:amd64 (0.25-6) ...
Selecting previously unselected package nfs-common.
Preparing to unpack .../nfs-common_1%3a1.3.4-6_amd64.deb ...
Unpacking nfs-common (1:1.3.4-6) ...
Selecting previously unselected package nfs-kernel-server.
Preparing to unpack .../nfs-kernel-server_1%3a1.3.4-6_amd64.deb ...
Unpacking nfs-kernel-server (1:1.3.4-6) ...
Setting up rpcbind (1.2.5-9) ...
insserv: script nginx_bak: service nginx already provided!
Created symlink /etc/systemd/system/multi-user.target.wants/rpcbind.service → /lib/systemd/system/rpcbind.service.
Created symlink /etc/systemd/system/sockets.target.wants/rpcbind.socket → /lib/systemd/system/rpcbind.socket.
Setting up keyutils (1.6.1-2) ...
Setting up libnfsidmap2:amd64 (0.25-6) ...
Setting up nfs-common (1:1.3.4-6) ...
Creating config file /etc/idmapd.conf with new version
Adding system user statd' (UID 110) ...
Adding new user
statd' (UID 110) with group nogroup' ...
Not creating home directory
/var/lib/nfs'.
Created symlink /etc/systemd/system/multi-user.target.wants/nfs-client.target → /lib/systemd/system/nfs-client.target.
Created symlink /etc/systemd/system/remote-fs.target.wants/nfs-client.target → /lib/systemd/system/nfs-client.target.
nfs-utils.service is a disabled or a static unit, not starting it.
Setting up nfs-kernel-server (1:1.3.4-6) ...
Created symlink /etc/systemd/system/multi-user.target.wants/nfs-server.service → /lib/systemd/system/nfs-server.service.
A dependency job for nfs-server.service failed. See 'journalctl -xe' for details.
Creating config file /etc/exports with new version
Creating config file /etc/default/nfs-kernel-server with new version
invoke-rc.d: initscript nfs-kernel-server, action "start" failed.
● nfs-server.service - NFS server and services
Loaded: loaded (]8;;file://webserver/lib/systemd/system/nfs-server.service/lib/systemd/system/nfs-server.service]8;;; enabled; vendor preset: enabled)
Active: inactive (dead)
Nov 13 13:24:35 webserver systemd[1]: [0;1;38;5;185m[0;1;39m[0;1;38;5;185mDependency failed for NFS server and services.[0m
Nov 13 13:24:35 webserver systemd[1]: [0;1;39m[0;1;31m[0;1;39mnfs-server.service: Job nfs-server.service/start failed with result 'dependency'.[0m
Nov 13 13:24:36 webserver systemd[1]: [0;1;38;5;185m[0;1;39m[0;1;38;5;185mDependency failed for NFS server and services.[0m
Nov 13 13:24:36 webserver systemd[1]: [0;1;39m[0;1;31m[0;1;39mnfs-server.service: Job nfs-server.service/start failed with result 'dependency'.[0m
Failed to start nfs-kernel-server, ignoring.
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for libc-bin (2.31-13+deb11u7) ...
Synchronizing state of rpcbind.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable rpcbind
LC_ALL = (unset),
LC_ALL = (unset),
--2023-11-13 13:24:37-- https://node.aapanel.com/install/plugin/nfs_tools_en/nfs_tools.zip
Resolving node.aapanel.com (node.aapanel.com)... 104.21.79.196, 172.67.171.7, 2606:4700:3034::ac43:ab07, ...
Length: 2572283 (2.5M) [application/zip]
Saving to: '/www/server/panel/plugin/nfs_tools/nfs_tools.zip'
0K .......... .......... .......... .......... .......... 1% 4.26M 1s
50K .......... .......... .......... .......... .......... 3% 219K 6s
100K .......... .......... .......... .......... .......... 5% 222K 7s
150K .......... .......... .......... .......... .......... 7% 4.42M 5s
200K .......... .......... .......... .......... .......... 9% 4.01M 4s
250K .......... .......... .......... .......... .......... 11% 4.31M 4s
300K .......... .......... .......... .......... .......... 13% 253K 4s
350K .......... .......... .......... .......... .......... 15% 4.35M 4s
400K .......... .......... .......... .......... .......... 17% 4.47M 3s
450K .......... .......... .......... .......... .......... 19% 4.30M 3s
500K .......... .......... .......... .......... .......... 21% 4.50M 3s
550K .......... .......... .......... .......... .......... 23% 4.23M 2s
600K .......... .......... .......... .......... .......... 25% 4.54M 2s
650K .......... .......... .......... .......... .......... 27% 4.22M 2s
700K .......... .......... .......... .......... .......... 29% 3.33M 2s
750K .......... .......... .......... .......... .......... 31% 362K 2s
800K .......... .......... .......... .......... .......... 33% 4.24M 2s
850K .......... .......... .......... .......... .......... 35% 4.50M 2s
900K .......... .......... .......... .......... .......... 37% 4.23M 2s
950K .......... .......... .......... .......... .......... 39% 4.52M 1s
1000K .......... .......... .......... .......... .......... 41% 4.26M 1s
1050K .......... .......... .......... .......... .......... 43% 4.52M 1s
1100K .......... .......... .......... .......... .......... 45% 3.19M 1s
1150K .......... .......... .......... .......... .......... 47% 4.49M 1s
1200K .......... .......... .......... .......... .......... 49% 4.37M 1s
1250K .......... .......... .......... .......... .......... 51% 4.68M 1s
1300K .......... .......... .......... .......... .......... 53% 4.35M 1s
1350K .......... .......... .......... .......... .......... 55% 4.62M 1s
1400K .......... .......... .......... .......... .......... 57% 4.39M 1s
1450K .......... .......... .......... .......... .......... 59% 4.65M 1s
1500K .......... .......... .......... .......... .......... 61% 3.43M 1s
1550K .......... .......... .......... .......... .......... 63% 4.38M 1s
1600K .......... .......... .......... .......... .......... 65% 1.13M 1s
1650K .......... .......... .......... .......... .......... 67% 5.53M 1s
1700K .......... .......... .......... .......... .......... 69% 5.84M 1s
1750K .......... .......... .......... .......... .......... 71% 5.52M 0s
1800K .......... .......... .......... .......... .......... 73% 5.82M 0s
1850K .......... .......... .......... .......... .......... 75% 5.60M 0s
1900K .......... .......... .......... .......... .......... 77% 4.36M 0s
1950K .......... .......... .......... .......... .......... 79% 5.54M 0s
2000K .......... .......... .......... .......... .......... 81% 5.86M 0s
2050K .......... .......... .......... .......... .......... 83% 5.52M 0s
2100K .......... .......... .......... .......... .......... 85% 5.88M 0s
2150K .......... .......... .......... .......... .......... 87% 5.47M 0s
2200K .......... .......... .......... .......... .......... 89% 5.93M 0s
2250K .......... .......... .......... .......... .......... 91% 5.95M 0s
2300K .......... .......... .......... .......... .......... 93% 4.52M 0s
2350K .......... .......... .......... .......... .......... 95% 6.52M 0s
2400K .......... .......... .......... .......... .......... 97% 6.32M 0s
2450K .......... .......... .......... .......... .......... 99% 7.07M 0s
2500K .......... . 100% 19.6M=1.3s
2023-11-13 13:24:39 (1.88 MB/s) - '/www/server/panel/plugin/nfs_tools/nfs_tools.zip' saved [2572283/2572283]
Archive: nfs_tools.zip
inflating: BT-NFS-MOUNT
inflating: icon.png
inflating: index.html
inflating: info.json
inflating: init.sh
inflating: install.sh
inflating: repair.sh
inflating: upgrade.sh
inflating: nfs_tools_main.cpython-37m-x86_64-linux-gnu.so
inflating: nfs_tools_main.so
inflating: nfs_tools_main.cpython-36m-x86_64-linux-gnu.so
/tmp/nfs_tools.sh: line 24: sudo: command not found
error
Starting BT-NFS-MOUNT service... [32mdone[0m
Successify
