2023-11-09T18:55:21.488115Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488120Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488123Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488127Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488131Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488135Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488138Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488148Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488152Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488156Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488159Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488164Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488167Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488171Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488175Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488179Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488182Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488186Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488190Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488194Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488197Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488203Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488254Z 0 [ERROR] InnoDB: Trying to do I/O to a tablespace which does not exist. I/O type: read, page: [page id: space=1437, page number=3], I/O length: 16384 bytes
2023-11-09T18:55:21.488268Z 0 [ERROR] InnoDB: trying to read page [page id: space=1437, page number=3] in nonexisting or being-dropped tablespace
2023-11-09T18:55:21.488273Z 0 [ERROR] [FATAL] InnoDB: Unable to read page [page id: space=1437, page number=3] into the buffer pool after 100 attempts. The most probable cause of this error may be that the table has been corrupted. Or, the table was compressed with with an algorithm that is not supported by this instance. If it is not a decompress failure, you can try to fix this problem by using innodb_force_recovery. Please see http://dev.mysql.com/doc/refman/5.7/en/ for more details. Aborting...
2023-11-09 18:55:21 0x14f0e4760700 InnoDB: Assertion failure in thread 23024857646848 in file ut0ut.cc line 921
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
InnoDB: http://dev.mysql.com/doc/refman/5.7/en/forcing-innodb-recovery.html
InnoDB: about forcing recovery.
18:55:21 UTC - mysqld got signal 6 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
Attempting to collect some information that could help diagnose the problem.
As this is a crash and something is definitely wrong, the information
collection process might fail.
key_buffer_size=402653184
read_buffer_size=1048576
max_used_connections=0
max_threads=300
thread_count=0
connection_count=0
