tanjimreza Hello, My admin panel is accessible from http://ip1234:7800/tanjim I want it to access from http://domain.com:7800/tanjim/ How do I configure that? I have created redirect in cloudflare but that doesn't seem to be working. Thanks!
aaPanel_Kern Hello, Cloudflare does not support port 7800. The panel does not support the use of proxies. Some functions will not work properly after use.
tanjimreza aaPanel_Kern I have setup a redirect, now seems to be working. But Email service is not working, my port 25 is blocked. I used CyberPanel + Brevo Relay before but it is not working with aaPanel. Can you look into this?
aaPanel_Kern tanjimreza Hello, I suggest you check if port 25 is open? The server provider will ban port 25 debian/ubuntu: apt install telnet -y && telnet smtp.google.com 25 centos: yum install telnet -y && telnet smtp.google.com 25
