aaPanel_Kern It is recommended that you follow the prompts to check whether system hardening is used, and if so, please turn it off first. Also check if your hard drive has space: df -h && df -i useradmin
useradmin aaPanel_Kern I don't know what system enhancement software is. I only use the aapanel libraries. Other than that, I don't use anything else.Can you tell me what enhancement software is?
aaPanel_Kern useradmin Please check whether Website Tamper-proof and Tamper-proof for Enterprise restrict modifications to the /www directory?
useradmin aaPanel_Kern I did it but why cron with the url it doesn't work even though I didn't edit anything
useradmin aaPanel_Kern I still access the website normally, I curl with my computer and it still works, but curl on the vps running that website doesn't work.
aaPanel_Kern Incomplete screenshot Can't figure out what's wrong, or your site isn't returning anything useradmin
useradmin aaPanel_Kern root@vmi1203384:~# curl -kv mywebsite Trying 104.21.79.34:443... TCP_NODELAY set Connected to mywebsite (104.21.79.34) port 443 (#0) ALPN, offering h2 ALPN, offering http/1.1 successfully set certificate verify locations: CAfile: /etc/ssl/certs/ca-certificates.crt CApath: /etc/ssl/certs TLSv1.3 (OUT), TLS handshake, Client hello (1): TLSv1.3 (IN), TLS handshake, Server hello (2): TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8): TLSv1.3 (IN), TLS handshake, Certificate (11): TLSv1.3 (IN), TLS handshake, CERT verify (15): TLSv1.3 (IN), TLS handshake, Finished (20): TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1): TLSv1.3 (OUT), TLS handshake, Finished (20): SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384 ALPN, server accepted to use h2 Server certificate: subject: CN=mywebsite start date: Oct 7 03:44:37 2023 GMT expire date: Jan 5 03:44:36 2024 GMT issuer: C=US; O=Let's Encrypt; CN=E1 SSL certificate verify ok. Using HTTP2, server supports multi-use Connection state changed (HTTP/2 confirmed) Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0 Using Stream ID: 1 (easy handle 0x564f53c53300) GET / HTTP/2 Host: mywebsite user-agent: curl/7.68.0 accept: / TLSv1.3 (IN), TLS handshake, Newsession Ticket (4): TLSv1.3 (IN), TLS handshake, Newsession Ticket (4): old SSL session ID is stale, removing Connection state changed (MAX_CONCURRENT_STREAMS == 100)! < HTTP/2 520 < date: Thu, 09 Nov 2023 09:47:06 GMT < content-length: 0 < cache-control: no-store, no-cache < cf-cache-status: DYNAMIC < report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=QdZhsddo9AfEWLRznXdmHR%2FY%2FaLAEcENrsXJ%2Bpt0v2LevOOgRTKOYqTBseALokWhDZ3zL6yhczNFQTUME5uoXfXzjWF7HjhsSJ%2FBj28%2Fc3Cm%2BRoLmX0FRH%2BldQA%2F5bvU3T8%3D"}],"group":"cf-nel","max_age":604800} < nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800} < strict-transport-security: max-age=15552000; includeSubDomains; preload < expect-ct: max-age=86400, enforce < referrer-policy: same-origin < x-content-type-options: nosniff < x-frame-options: SAMEORIGIN < x-xss-protection: 1; mode=block < server: cloudflare < cf-ray: 823521e59c82160d-DUS < alt-svc: h3=":443"; ma=86400 < Connection #0 to host mywebsite left intact
useradmin aaPanel_Kern If it doesn't answer why can I still access and curl from my computer it still works, does this have anything to do with nginx's filewall?
aaPanel_Kern It is recommended that you check it yourself. You can use the browser to press F12, go to the network interface, visit again, and check it useradmin
