alvino Hello, I am trying to raise max_children from 80 to 90 with a Concurrency Plan 4GB and Running Mode On-demand after I save the Concurrency Plan automatically switches to 1GB I use php 7.4
idflorin this is the default for me: this for 1 gb and this for 4gb Works fine for me on centos 7 + Nginx + php4.
alvino idflorin Yes, it works fine for me. But, after I increase max_children and I save a Concurrency Plan 4GB automatically switches to 1GB
KrzysztofMaciejewski does OPTIMIZATION panel is available after activate WEBSITE SPEED AApanel plugin? in 7.3 PHP i don have this option
alvino aaPanel_Jose Previously this problem had occurred when I used php 7.3 then I replaced it with php 7.4 a few weeks ago I have also tried it on demo.aapanel.com and it automatically becomes 1GB after saving At first this only happened in Running Mode On-demand but now it also happens in Running Mode Dynamic
aaPanel_Jose alvino Because after you have modified the configuration, the panel cannot recognize the corresponding optimized configuration, so 1GB is displayed by default, but there is no need to worry about the configuration you modified will still take effect
aaPanel_Kern This is the content of the configuration file that the panel will not read. Subject to your actual settings Vevioz
