Hello Team, yesterday i create cron job for shell script task. i set the task should run every minutes. The Shell Script is :
/www/server/php/80/bin/php /www/wwwroot/absensi.hsp.net.id/bismillah/artisan schedule:run >> /dev/null 2>&1
when i execute the command it run successfully. But after that it doesn't run automatically every minutes. I should check execute again to run it. Where is the problem?
i check with command systemctl cron to make sure the cron service is running, and it is active and running. i attach the screenshoot bellow
