sorry my mistake...today i run cron again the shell script that i run is :
- * * * * cd /www/wwwroot/absensi.hsp.net.id/bismillah/ && php artisan schedule:run >> /dev/null 2>&1
after check the log the result is like this :
/www/server/cron/367fa354f8f27b4caa5681ed6d6a9f3b: line 4: BT-Panel: command not found
★[2023-11-03 09:26:56] Successful
after that i run this command in terminal :
cat /www/server/cron/367fa354f8f27b4caa5681ed6d6a9f3b
and the result is :
#!/bin/bash
PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:~/bin
export PATH
echo "----------------------------------------------------------------------------"
endDate=date +"%Y-%m-%d %H:%M:%S"
echo "★[$endDate] Successful"
the cron is not running after i check in the database. it should change the value on table
