After installing the panel on CentOS 7, SSL cannot be enabled.
Error, unable to auto install pyOpenSSL!
Plesea try to manually install: pip install pyOpenSSL
After executing 'btpython /www/server/panel/tools.py ssl' command, it displays
[root@localhost ~]# btpython /www/server/panel/tools.py ssl
File "/www/server/panel/tools.py", line 717, in <module>
CreateSSL()
File "/www/server/panel/tools.py", line 242, in CreateSSL
result = json.loads(public.httpPost(cert_api,{'data': json.dumps(pdata)}))
File "/www/server/panel/pyenv/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/www/server/panel/pyenv/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/www/server/panel/pyenv/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
How can this issue be resolved?
