Current logs. This was a brand new install only installed a few days ago. I have no idea what the issue is.
The only issue I can think of is potential of ubuntu firewall blocking port 8886 otherwise I cant see any other issues.
What other ports does aapanel to be open.
aapanel is installed via docker
Current configuration is cloudflare DNS (mydomain.com) -----> nginx proxy manager -----> aapanel docker
nginx proxy manager is open to internet via a single static ip address provided by my isp it is open on port 80 and 443 do other ports need to be open for aaPanel to work?
The current configuration that was working is https://aapanel.mydomain.com/aapanel however for some reason its not working now these are docker logs
I cant access the local internal ip address for aapanel i.e. 192.168.1.xxx:8886/aapanel so there are issues
docker inspect --format "Json.State.Health" 255bb87e6b3e
{"Status":"unhealthy","FailingStreak":25,"Log":[{"Start":"2023-10-25T12:21:21.953786388Z","End":"2023-10-25T12:21:22.015866435Z","ExitCode":1,"Output":""},{"Start":"2023-10-25T12:21:27.017836267Z","End":"2023-10-25T12:21:27.107318218Z","ExitCode":1,"Output":""},{"Start":"2023-10-25T12:21:32.111326547Z","End":"2023-10-25T12:21:32.179067901Z","ExitCode":1,"Output":""},{"Start":"2023-10-25T12:21:37.181443022Z","End":"2023-10-25T12:21:37.247018491Z","ExitCode":1,"Output":""},{"Start":"2023-10-25T12:21:42.249178901Z","End":"2023-10-25T12:21:42.32084723Z","ExitCode":1,"Output":""}]}
Stopping Bt-Tasks... done
Stopping Bt-Panel... done
Starting Bt-Panel.... done
Starting Bt-Tasks... done
