Not sure if I should post a new thread but probably it's better to write in this same one . It seems that the panel itself has quite a lot of leftover files when deleting a website . For example. Some months ago I removed a website and it had folders and files left corresponding to the ssl in vhos folder at /www/server/panel/vhost also in /www/server/panel/data/check_domain . And even though the website is fully deleted . The SSL renewal script still checks for that website starting from that particular website. Here is the log . Hope you can help fix the auto-renewal script
Also the acme_v2.py file returnes attribute error
|-The website has been suspended, skip certificate renewal!
|-A total of 5 certificates need to be renewed
|-Renew the visa certificate and start checking the environment
|-Renewing certificate number of 1,domain: ['fragransprestige.com']..
|-Creating order..
File "/www/server/panel/class/acme_v2.py", line 1909, in renew_cert
self._config['orders'][index]['auth_to'], index)
File "/www/server/panel/class/acme_v2.py", line 1773, in renew_cert_to
siteName = self.get_site_name_by_domains(domains)
AttributeError: 'acme_v2' object has no attribute 'get_site_name_by_domains'
★[2023-12-13 07:53:18] Successful
