aaP_yassarlenovo What should I do with this? This problem appeared after I pressed the fix button, after I pressed the fix button again, nothing happened, it stayed like this AttributeError: module 'lib' has no attribute 'OpenSSL_add_all_algorithms'
aaPanel_Kern aaP_yassarlenovo Hello, is it normal to use the ssh tool to execute the command and try again? mv /www/server/panel/pyenv/lib/python3.7/site-packages/OpenSSL /tmp/OpenSSL_bak btpip install pyOpenSSL -I bt reload
