and I have click "click install" many times, but it still let me click install
--2023-10-19 02:24:24-- https://node.aapanel.com/install/0/docker_install_en.sh
Length: 16976 (17K) [application/octet-stream]
Saving to: ‘docker_install_en.sh’
0K .......... ...... 100% 52.9M=0s
2023-10-19 02:24:24 (52.9 MB/s) - ‘docker_install_en.sh’ saved [16976/16976]
selecting download node...
https://na1-node.bt.cn
{"product": "Linux panel", "setup_path": "/www/server", "openlitespeed_path": "/usr/local", "language": "English", "title": "aaPanel Linux panel", "brand": "aaPanel", "root_path": "/www", "template": "default", "logs_path": "/www/wwwlogs", "home": "https://www.aapanel.com", "recycle_bin": true}
1
curl: (23) Failed writing body (0 != 1360)
chmod: cannot access '/usr/libexec/docker/cli-plugins/docker-compose': No such file or directory
Requirement already satisfied: pytz in ./pyenv/lib/python3.7/site-packages (2020.5)
WARNING: There was an error checking the latest version of pip.
Requirement already satisfied: docker in ./pyenv/lib/python3.7/site-packages (6.1.3)
Requirement already satisfied: packaging>=14.0 in ./pyenv/lib/python3.7/site-packages (from docker) (23.2)
Requirement already satisfied: requests>=2.26.0 in ./pyenv/lib/python3.7/site-packages (from docker) (2.31.0)
Requirement already satisfied: urllib3>=1.26.0 in ./pyenv/lib/python3.7/site-packages (from docker) (1.26.2)
Requirement already satisfied: websocket-client>=0.32.0 in ./pyenv/lib/python3.7/site-packages (from docker) (0.57.0)
Requirement already satisfied: charset-normalizer<4,>=2 in ./pyenv/lib/python3.7/site-packages (from requests>=2.26.0->docker) (3.3.0)
Requirement already satisfied: idna<4,>=2.5 in ./pyenv/lib/python3.7/site-packages (from requests>=2.26.0->docker) (2.10)
Requirement already satisfied: certifi>=2017.4.17 in ./pyenv/lib/python3.7/site-packages (from requests>=2.26.0->docker) (2020.12.5)
Requirement already satisfied: six in ./pyenv/lib/python3.7/site-packages (from websocket-client>=0.32.0->docker) (1.15.0)
/bin/systemctl
Warning: Stopping docker.service, but it can still be activated by:
docker.socket
