Length: 5296 (5.2K) [application/octet-stream]
Saving to: ‘docker.sh’
0K ..... 100% 17.0M=0s
2023-10-17 11:49:32 (17.0 MB/s) - ‘docker.sh’ saved [5296/5296]
selecting download node...
https://na1-node.bt.cn
{"product": "Linux panel", "setup_path": "/www/server", "openlitespeed_path": "/usr/local", "language": "English", "title": "aaPanel Linux panel", "brand": "aaPanel", "root_path": "/www", "template": "default", "logs_path": "/www/wwwlogs", "home": "https://www.aapanel.com", "recycle_bin": true}
https://node.aapanel.com
--2023-10-17 11:49:44-- https://node.aapanel.com/install/plugin/docker_en/docker_main.py
Resolving node.aapanel.com (node.aapanel.com)... 104.21.79.196, 172.67.171.7, 2606:4700:3031::6815:4fc4, ...
Length: 26767 (26K) [application/octet-stream]
Saving to: ‘/www/server/panel/plugin/docker/docker_main.py’
0K .......... .......... ...... 100% 3.53M=0.007s
2023-10-17 11:49:44 (3.53 MB/s) - ‘/www/server/panel/plugin/docker/docker_main.py’ saved [26767/26767]
--2023-10-17 11:49:44-- https://node.aapanel.com/install/plugin/docker_en/index.html
Length: unspecified [text/html]
Saving to: ‘/www/server/panel/plugin/docker/index.html’
0K .......... .......... .......... .......... .......... 972K
50K ....... 2.27M=0.05s
2023-10-17 11:49:45 (1.03 MB/s) - ‘/www/server/panel/plugin/docker/index.html’ saved [59368]
--2023-10-17 11:49:45-- https://node.aapanel.com/install/plugin/docker_en/info.json
Length: 337 [application/json]
Saving to: ‘/www/server/panel/plugin/docker/info.json’
0K 100% 22.5M=0s
2023-10-17 11:49:45 (22.5 MB/s) - ‘/www/server/panel/plugin/docker/info.json’ saved [337/337]
--2023-10-17 11:49:45-- https://node.aapanel.com/install/plugin/docker_en/icon.png
Length: 1499 (1.5K) [image/png]
Saving to: ‘/www/server/panel/plugin/docker/icon.png’
0K . 100% 9.47M=0s
2023-10-17 11:49:46 (9.47 MB/s) - ‘/www/server/panel/plugin/docker/icon.png’ saved [1499/1499]
--2023-10-17 11:49:46-- https://node.aapanel.com/install/plugin/docker_en/login-docker.html
HTTP request sent, awaiting response... 404 Not Found
2023-10-17 11:49:47 ERROR 404: Not Found.
--2023-10-17 11:49:47-- https://node.aapanel.com/install/plugin/docker_en/userdocker.html
2023-10-17 11:49:49 ERROR 404: Not Found.
--2023-10-17 11:49:49-- https://node.aapanel.com/install/0/docker_install.sh
Length: 16938 (17K) [application/octet-stream]
Saving to: ‘/www/server/panel/install/docker_install.sh’
0K .......... ...... 100% 8.86M=0.002s
2023-10-17 11:49:50 (8.86 MB/s) - ‘/www/server/panel/install/docker_install.sh’ saved [16938/16938]
/www/server/panel/install/docker_install.sh: line 53: : No such file or directory
[1;31mNo mirrors available.
