Delinquent Warning: Unnecessary HSTS header over HTTP The HTTP page at http://siteurl.com sends an HSTS header. This has no effect over HTTP, and should be removed. How to fix this on Nginx WordPress?
Delinquent aaPanel_Kern Yes, my site is using https, but it is still showing this 307 internal redirect. How can I remove it or make it 200 or 301?
aaPanel_Kern Delinquent Hello, I suggest you check the configuration of the site to see if redirection is set?
