Hello,
I have a PHP project, and it's scraping data from other websites. My server is a fresh one with Ubuntu 22.04 as the operating system.
When I manually install the LEMP stack and upload my project, the scraping works perfectly. However, if I reset the server and install aapanel, and then install the LEMP stack with the same versions, the scraping doesn't work, and the other websites block my scraping attempts.
The other websites use Cloudflare, and when I attempt to scrape them using aapanel, they detect my server's requests as potentially automated or suspicious. This doesn't happen if I use the LEMP stack manually on the same server with the same project and code.
Do you have any ideas or reasons for this issue?
