aaPanel_Kern aaP_rstpers5 Hello, is it normal to use the ssh tool? Is the server provider's VNC normal? Check the version btpip list|grep simple-websocket
aaPanel_Kern aaP_rstpers5 Use the server provider's VNC execution command to start ssh and see why systemctl start sshd systemctl status sshd
aaPanel_Kern Hello, it is recommended that you check whether your yum source is configured correctly. You can ask the server provider to assist you in configuring it. aaP_rstpers5
