hi
i have same problem
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -5] No address associated with hostname'))
REQUEST_DATE: 2024-01-07 14:30:47
PAN_VERSION: 6.8.31
OS_VERSION: Ubuntu 20.04.6 LTS x86_64(Py3.7.9)
REMOTE_ADDR: 94.49.214.97
REQUEST_URI: POST /plugin?action=get_soft_list
REQUEST_FORM: {'p': '1', 'type': '0', 'tojs': 'soft.get_list', 'force': '1', 'query': ''}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:121.0) Gecko/20100101 Firefox/121.0
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 175, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 72, in create_connection
File "src/gevent/event.py", line 306, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 336, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 324, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 304, in gevent.gevent_cevent.AsyncResult.raise_exception
socket.gaierror: [Errno -5] No address associated with hostname
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 722, in urlopen
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 404, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1058, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 363, in connect
self.sock = conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 187, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -5] No address associated with hostname
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 450, in send
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 800, in urlopen
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 592, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -5] No address associated with hostname'))
File "/www/server/panel/BTPanel/init.py", line 1812, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1764, in run
File "class/panelPlugin.py", line 690, in get_soft_list
softList = self.get_cloud_list(get)
File "class/panelPlugin.py", line 366, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 117, in post
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 529, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 645, in send
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 519, in send
