aaPanel_Kern Hello, what version of phpmyadmin are you using? What is the php version used by phpmyadmin? Is it normal to try changing to php7.4? aaP_jfxprofit
aaP_jfxprofit aaPanel_Kern Hi admin, I'm using PHP8.1. Ok, I will try to switch to 7.4 and see what happens. My Phpmyadmin 5.0
aaP_jfxprofit aaPanel_Kern Hi admin, Yes, to make it work, I set the php version to 8.0 in the phpmyadmin setting. Now everything is back to normal.
