mdashikrahmanrabbi 404 Not Found nginx What's the problem? How do I fix the same file I use at Apache, but Nginx is not working?
aaPanel_Kern This needs to be set according to your website program. It is recommended to check the website program provider's website.
aaPanel_Kern SoftAP This needs to be set according to your website program. It is recommended to check the website program provider's website. ps:wordpress
mdashikrahmanrabbi aaPanel_Kern are you here brother? please reply i am using PHP so what do i select here?
aaPanel_Kern mdashikrahmanrabbi Hello, please set it according to the php supported by your website program.
aaPanel_Kern SoftAP Hello, it is recommended that you consult the website developer and set the routing settings according to the program. It is recommended that you check the website log and error log
aaPanel_Kern Hello, please check the website log and error log. What information is displayed when other interfaces cannot be opened? Do relevant documents exist? Can you provide more information or screenshots? 404 means the file cannot be found. SoftAP mdashikrahmanrabbi
