ERROR: FPM initialization failed?
I don't think it talks about the Elementor error here, what should I do to adjust the error...
[21-Aug-2023 21:22:42] NOTICE: fpm is running, pid 293492
[21-Aug-2023 21:22:42] NOTICE: ready to handle connections
[21-Aug-2023 22:47:04] NOTICE: Terminating ...
[21-Aug-2023 22:47:04] NOTICE: exiting, bye-bye!
[21-Aug-2023 22:49:44] NOTICE: fpm is running, pid 1008
[21-Aug-2023 22:49:44] NOTICE: ready to handle connections
[22-Aug-2023 01:57:20] NOTICE: Finishing ...
[22-Aug-2023 01:57:20] NOTICE: exiting, bye-bye!
[22-Aug-2023 01:59:58] NOTICE: fpm is running, pid 1018
[22-Aug-2023 01:59:58] NOTICE: ready to handle connections
[22-Aug-2023 17:44:06] NOTICE: Reloading in progress ...
[22-Aug-2023 17:44:06] NOTICE: reloading: execvp("/www/server/php/80/sbin/php-fpm", {"/www/server/php/80/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/80/etc/php-fpm.conf", "--pid", "/www/server/php/80/var/run/php-fpm.pid"})
[22-Aug-2023 17:44:06] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-80.sock
[22-Aug-2023 17:44:06] ERROR: FPM initialization failed
[22-Aug-2023 17:44:06] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-80.sock"
[22-Aug-2023 17:44:06] NOTICE: fpm is running, pid 16461
[22-Aug-2023 17:44:06] NOTICE: ready to handle connections
[22-Aug-2023 17:44:57] NOTICE: Reloading in progress ...
[22-Aug-2023 17:44:57] NOTICE: reloading: execvp("/www/server/php/80/sbin/php-fpm", {"/www/server/php/80/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/80/etc/php-fpm.conf", "--pid", "/www/server/php/80/var/run/php-fpm.pid"})
[22-Aug-2023 17:44:57] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-80.sock"
[22-Aug-2023 17:44:57] NOTICE: fpm is running, pid 16506
[22-Aug-2023 17:44:57] NOTICE: ready to handle connections
[22-Aug-2023 17:45:16] NOTICE: Reloading in progress ...
[22-Aug-2023 17:45:16] NOTICE: reloading: execvp("/www/server/php/80/sbin/php-fpm", {"/www/server/php/80/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/80/etc/php-fpm.conf", "--pid", "/www/server/php/80/var/run/php-fpm.pid"})
[22-Aug-2023 17:45:16] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-80.sock"
[22-Aug-2023 17:45:16] NOTICE: fpm is running, pid 16560
[22-Aug-2023 17:45:16] NOTICE: ready to handle connections
[22-Aug-2023 17:45:16] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-80.sock
[22-Aug-2023 17:45:16] ERROR: FPM initialization failed
[23-Aug-2023 15:41:28] NOTICE: Reloading in progress ...
[23-Aug-2023 15:41:28] NOTICE: reloading: execvp("/www/server/php/80/sbin/php-fpm", {"/www/server/php/80/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/80/etc/php-fpm.conf", "--pid", "/www/server/php/80/var/run/php-fpm.pid"})
[23-Aug-2023 15:41:28] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-80.sock"
[23-Aug-2023 15:41:28] NOTICE: fpm is running, pid 38256
[23-Aug-2023 15:41:28] NOTICE: ready to handle connections
[23-Aug-2023 15:41:50] NOTICE: Reloading in progress ...
[23-Aug-2023 15:41:50] NOTICE: reloading: execvp("/www/server/php/80/sbin/php-fpm", {"/www/server/php/80/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/80/etc/php-fpm.conf", "--pid", "/www/server/php/80/var/run/php-fpm.pid"})
[23-Aug-2023 15:41:50] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-80.sock"
[23-Aug-2023 15:41:50] NOTICE: fpm is running, pid 38299
[23-Aug-2023 15:41:50] NOTICE: ready to handle connections
[23-Aug-2023 15:41:50] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-80.sock
[23-Aug-2023 15:41:50] ERROR: FPM initialization failed
[18-Sep-2023 14:08:41] NOTICE: Reloading in progress ...
[18-Sep-2023 14:08:41] NOTICE: reloading: execvp("/www/server/php/80/sbin/php-fpm", {"/www/server/php/80/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/80/etc/php-fpm.conf", "--pid", "/www/server/php/80/var/run/php-fpm.pid"})
[18-Sep-2023 14:08:41] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-80.sock
[18-Sep-2023 14:08:41] ERROR: FPM initialization failed
[18-Sep-2023 14:08:41] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-80.sock"
[18-Sep-2023 14:08:41] NOTICE: fpm is running, pid 513357
[18-Sep-2023 14:08:41] NOTICE: ready to handle connections
[18-Sep-2023 16:03:10] NOTICE: Finishing ...
[18-Sep-2023 16:03:10] NOTICE: exiting, bye-bye!
[18-Sep-2023 16:03:55] NOTICE: fpm is running, pid 516668
[18-Sep-2023 16:03:55] NOTICE: ready to handle connections
[18-Sep-2023 18:16:48] NOTICE: Reloading in progress ...
[18-Sep-2023 18:16:48] NOTICE: reloading: execvp("/www/server/php/80/sbin/php-fpm",
