Hi,
I can't see any incoming emails in my aapanel mail server Inbox. (Though, I can see the email logs in rspamd GUI history tab)
Below are the logs;
Sep 18 14:33:55 mail postfix/smtps/smtpd[2303]: lost connection after AUTH from unknown[46.148.40.87]
Sep 18 14:33:55 mail postfix/smtps/smtpd[2303]: disconnect from unknown[46.148.40.87] ehlo=1 auth=0/1 rset=1 commands=2/3
Sep 18 14:33:58 mail postfix/smtps/smtpd[2302]: warning: unknown[46.148.40.189]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Sep 18 14:33:59 mail postfix/smtpd[2728]: connect from earthmovi[::1]
Sep 18 14:33:59 mail postfix/smtpd[2728]: 659551F4508: client=earthmovi[::1], sasl_method=PLAIN, sasl_username=adam@earthmovi.com.
Sep 18 14:33:59 mail postfix/cleanup[2729]: 659551F4508: message-id=<20230918143359.659551F4508@mail.earthmovi.com>
Sep 18 14:34:00 mail postfix/qmgr[1252]: 659551F4508: from=<adam@earthmovi.com>, size=761, nrcpt=1 (queue active)
Sep 18 14:34:00 mail postfix/smtp[2742]: connect to gmail-smtp-in.l.google.com[2404:6800:4003:c04::1b]:25: Network is unreachable
Sep 18 14:34:00 mail postfix/smtpd[2728]: disconnect from earthmovi[::1] ehlo=1 auth=1 mail=1 rcpt=1 data=1 commands=5
Sep 18 14:34:01 mail postfix/smtps/smtpd[2303]: connect from unknown[46.148.40.140]
Sep 18 14:34:01 mail postfix/smtps/smtpd[2302]: lost connection after AUTH from unknown[46.148.40.189]
Sep 18 14:34:01 mail postfix/smtps/smtpd[2302]: disconnect from unknown[46.148.40.189] ehlo=1 auth=0/1 rset=1 commands=2/3
Sep 18 14:34:02 mail postfix/smtp[2742]: 659551F4508: to=<bonka@gmail.com>, relay=gmail-smtp-in.l.google.com[64.233.170.26]:25, delay=3.5, delays=0.68/0.02/1.4/1.5, dsn=2.0.0, status=sent (250 2.0.0 OK 1695047642 i191-20020a6387c8000000b00553c2f85095si7932553pge.832 - gsmtp)
Sep 18 14:34:02 mail postfix/qmgr[1252]: 659551F4508: removed
Sep 18 14:34:04 mail postfix/smtps/smtpd[2309]: warning: unknown[46.148.40.192]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Sep 18 14:34:06 mail postfix/smtps/smtpd[2304]: warning: unknown[46.148.40.195]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Sep 18 14:34:07 mail postfix/smtps/smtpd[2309]: lost connection after AUTH from unknown[46.148.40.192]
Sep 18 14:34:07 mail postfix/smtps/smtpd[2309]: disconnect from unknown[46.148.40.192] ehlo=1 auth=0/1 rset=1 commands=2/3
I already tried restarting the server but no luck. My domain mail records are all green/verified. Port 25 open because I am able to send outgoing emails.
I am wondering why my inbox is not showing any emails?
Help please,
