aaP_benchoitarrazona I restart my server in aapanel then i got lost internet connection and refresh the page then my account will logout and show this error help me
aaPanel_Kern Hello, please go to the server provider's management website to check whether the server is normal? You can try using the server provider's VNC to see if it is running. aaP_benchoitarrazona
aaPanel_Kern It is recommended that you use this website to check whether the relevant ports are open? https://dnschecker.org/port-scanner.php View panel link using bt 14 Use bt status to check if it is running Also check whether the system firewall opens relevant ports aaP_benchoitarrazona
aaP_benchoitarrazona aaPanel_Kern i alreadt check the port in that link Custom Port # 1 7800 Timed-Out Custom Port # 2 53 Timed-Out Custom Port # 3 22 Open Custom Port # 4 888 Open Custom Port # 5 80 Open
aaPanel_Kern Hello, I suggest you solve it first. The problem of not being able to use yum first aaP_benchoitarrazona
